Fascinate Deck Dock Tip
Droidus
If you are using Launcher Pro with a desk dock and have lost the insta dock app launch ability once you place the phone in the dock, I have a semi-solution for you. Dock you phone as you would normally and just press the home soft key(the one that lights up on the bottom of your screen), it should launch your dock app instanly. This prevents you from having the shortcut in your home screen and having to press it once you dock the phone.
