Root Fassy with blue tinted screen with some roms
Wizardawd
I have a Fazzy that I have had since release and it has been a very good phone to me. The last year I started rooting and have had great fun with all the different roms, etc. When 4.0 roms were ported over I had to try.
Team Hacksung build 1 and 2 flashed just fine and it was gorgeous, albeit a tad unstable. When Build 3 came, I flashed and while it does work, the color tuning is incredibly BLUE. And I mean everything is blue. I went back to build 2 and everything was fine again. After many reflashes, etc., i went to a powerewashed GB for a while. Got bored with that and tried CM7. When I saw they where deep into more stable builds of ICS, I flashed those and yet again, Blue.
I tried everything, different roms, different team builds, MIUI, MTD, etc. Made sure I was on the most recent CWM. Still blue AFTER build 2. After some reading, I figured I should give a new sd card a try. So going from the OEM Samsung Class 4 16g to a Class 10 PNY 16g and same results.
If it helps, I'm guessing it could be something to do with the kernal used as that was changed after build 2. And even CWM and Samsung startup screen is blue. Going into the color tuning screen on some builds there is an option to change blue color. But, it does absolutely nothing until the last setting then all blue disappears. If it is the kernal, which should I use? Not a big person to overclock, etc. And I've always been happy with battery life.
Anyways, thanks in advance for any advice or suggestions.
Aaron
Samsung Fazzy - Unknown Blue Light Special
HTC Incredible 2 - Washed stock
LG Vortex - Rooted and retired
HP Touchpad - ICS Goodness
Soon to add Galaxy S3
