Help fastboot command
  • Start date Start date
A
Android Question
Guest
How would I use the command fastboot getvar all? Does this require a computer or can it be used on the phone? What is fastboot?
Welcome to our AndroidForums :).
The fastboot utility does indeed require a PC.
It also typically requires specific USB drivers if you're using a Windows PC (Linux / Mac is a bit easier, but likely requires using sudo).
It also requires that your device is booted into what is called fastboot or bootloader mode (some a small number of (stubborn) devices that won't even show you the bootloader screen).
fastboot is a utility for interacting with the bootloader to do device-specific things (checking the bootloader lock state, flashing the boot or recovery partitions, etc.).
The functionality does vary by device and whether or not the bootloader is unlocked, though.
