Root fastboot mode and hboot flashing? :/
dan55
Android Expert
hi all,
ok im now s-off :) that was easy with Rev.
have copied the cm7v2 .img file to sd card
did back button plus power for fastboot - but now not sure what to do :/
i sort of expected fastboot to give me a black command line screen so i could type in the hboot flash commands :/ have i got this wrong?
.....or is it just a mode toggle selection?
thanks
dan
....ah - does the phone have to be sat on the fastboot screen, and then i do the commands from pc - or run android flasher etc?
cheers
Congratulations on s-off Dan....
To flash a new h boot I done it using Android flasher with the phone connected to the PC on fast boot mode
You can also use cmd line but o found the flasher the easiest way to go
Hope this helps
Paul
You dont put the hboot on sd card. You put it on C: drive. Like Paul says, you use command prompt. Please read my fastboot faq. All is explained there
hi Paul. thanks :-) it was very easy. so much so wasn't sure it had done anything :-D
ok cool thanks.
hi Dan.
thanks. yes realised my stupidity :-D
do I need any of that Linux shell stuff on pc? or just flasher .exe
thanks
dan
If you're going to use flasher, thats all you need. Whatever is packaged with its download.
question:
does my UOT kitchen cm7 theme sit outside the rom area of memory? just wondering if i shouldnt flash it :/
i think it sits in normal app area as when i install one each time that space went down - but not sure
cheers
a*se - stuck on htc screen after boot flash :( :(
....do i try and force powerdown - wipte etc...... :/
pulled battery - recovery - going for full wipe and rom flash
....also going for pair of pants number 2!! :o :D
F'me that was scary! :o :D
cm7 flashed back - seemed to take longer to sort it self out on htc screen after flash - but eventually came good
over 200mb free! :D cool and the gang :)
