Root fastboot mode??
chrisjv3393
Does this phn have a fastboot mode by a combination of buttons on the phn? Bcuz my phn is stuck in a bootloop n I dntt know any other way to get my computer to recognize my phn
no, there is no button combination. holding up and power goes into ftm mode though, which from what people say should allow you to run the zte update tool from their website to reflash the phone. unless you have cwm of course which in that case A you should have made a backup and tested that it worked correctly in the first place and B you can restore your system from that anyway. all you gotta do is replace what got messed up, someone can easily upload their system dump for you in installable zip form, its just whether or not any of us have the time and i unfortunately do not
unfortunately im on stock recovery now. so cwm is useless for me. n i did make a backup n restored it but its a back up of the messed up boot.img with it sooo yeaaa...me n my dumb mistakes. but im trying the zte update tool now. just gotta install it
unfortunately im on the stock recovery now so cwm is useless to me. but i guess i need a new boot.img cuz mines is screwed up. but im trying zte update tool just waiting for it to download
Phone has been fixed thanks to zte update tool! Gonna make backups of both stock rom with cwm and a rooted stock rom just in case anyone needs it :d....brb
that would be awesome of you, once its done being made just make sure it was made correctly by restoring it, if it restores and passes the md5 check i you can zip it all up and upload it for everyone. i was gonna do that but itd take days on my slow internet connection, if it even stayed stable enough, then theres the whole issue of my personal data, i had already set up google and everything before i made the recovery so my data folder holds my personal information. and im not giving that to the world. so yea i never got around to being able to make it
on it now!
i got md5 mismatch.....its basicly a backup of my 100% stock rom no root with cwm recovery on it.. i didnt think itll even be able to flash on it witout root but it did easily lol but im tryna root it but the program keeps saying something about cant locate path or somethin
thats odd, but yea if you get the md5 it is possibly a bad backup and im not even sure if itll restore properly. rooting it again is another matter entirely, i dont know why the root program would be giving you problems. try redownloading the program that roots it and go from there. and thanks for doin this itll save alot of lives
No worries maaan i got it all done n working fine. Im uploading the stock rooted rom now to 4shared.com cuz mediafire wanna b a dick n limit my upload to 200mb lol
sounds good, make sure you make a new thread for it so people can find it and youll be a hero. at least to one guy i know lol
