Once your phone is programmed (*228 option 1) I'm not sure why you would need to re-program it again unless you installed a custom ROM or did a factory data reset. At that point all you'd normally need to do is to update the PRL through *228 option 2.
Once upon a time a quicker way to update PRL was to do a *22899...
