Help Favorite contacts
gwolf
I just got the Galaxy S4 on Verizon, I want to make a favorite contacts widget, I have looked everywhere in the phone to try to make it, Its in the apps section the the application management, but its not in my widget listings, or in the contact options/settings... help?
Is there a more or additional option when looking at the widget list? Often they only populate the choices with what they think will be most used. I don't have a S4 so I'm just taking a wild guess. Best of luck to you and way grats on that new S4.
Thank you, I needed the upgrade from the LG G2x... but I've looked for a more option and their is none unfortunately
