If you want to edit your "Favorites" use the "People" application. That holds all your contacts.
The Favorites widget determines who to put there based on the category called "Favorites" in the People application.
I could not figure out how to change the style of the "Favorites" widget when I first got the phone so I deleted the widget and re-added it. At that point it asks you what style of widget you want.
The other thing is the default action for a given contact. You should be able to edit that as well under the People application.
FYI the "People" application seems to be the contact manager for Sense.
Makes perfect sense. I have done the same thing. Mess up one contact and have to delete the widget and start over. Thanks that was the answer I was looking for.
