Root FC every where with CM7
cipher6
I've been running the stable CM7 on my dinc since it first came out, with no major issues. But within the last couple of days, I've been getting FC issues constantly. Reboots, battery pulls don't seem to work. And it comes and goes, sometimes it will be fine for a few hours, other times any thing I touch will FC.
I didn't make any changes or install any new apps before this happened.
Any ideas?
running fix permissions in rom manager might work. Then reboot afterwards, that's my only idea. I haven't had this problem on any version of CM7.
I know this thread is a couple days old but I am having a similiar issue now. Seems to start when I am using Dolphin Browser HD which crashes, and when I try to send a an error report, before I can even do that, gmail crashes. Next tried to open a gaming app, which FCed twice before I was able to open it. Been running CM7 stable for a couple weeks with no issue till Dolphin started acting up last night... any thoughts?
Well, it got worse, tried a reboot and as soon as it started, everything started FCing, google framework, all my apps, extra, having to do a restore from clockwork to just a stock root. If anyone has ideas, please let me know, would prefer to go back to CM7 unless I find something else I like.
I was having the same issue about a week ago. Dolphin started crashing and every app I tried to run fc'd on me. It was late at night and I didn't feel like messing around, so I powered down and charged it. The next morning every thing seemed fine. Later that day the fc issues came back, fix permissions from rom manager did nothing. Long story short, I had to do a clean flash of cm7, now every thing works flawlessly. Probably not what you wanted to hear, but I hope this helps. Good luck.
Fresh,clean install was going to be my suggestion as well. :) also make sure you're not attempting to restore any system data with titanium. ONLY restore user apps and their data
This has been a constant problem for me with CM7. It just started again this morning. Check your contacts after you do a fresh install because this has erased a bunch of contacts on me in the past. I think I am going to downgrade to CM6.1 as I am tired of having to deal with this issue all the time.
You are correct, not what I wanted to hear, but worth a shot. And yea, I knew, now, not to restore system data, only app stuff, learned that the hard way 8-) Thanx
According to a thread on the CM forums, the contacts database can become corrupt, which in turn causes every database on the device to somehow be corrupt.
A temporary fix is to turn off contact syncing, clearing the data from "Contacts Storage" and "Google Services Framework", rebooting, and re-enabling contact sync.
This has been happening to me as well, and that temporary fix no longer works for me. I'm switching to another ROM.
Edit:
See this thread:
http://forum.cyanogenmod.com/topic/24484-lots-of-google-framework-failuresrebooting-needed/
From the above thread:
Okay here are my thoughts on this. There are a couple things which can cause these problems. One is the bug in the Android OS which is supposedly fixed in Android 2.3.4 (CM7 nightlies uses this version) which causes the same symptoms everyone here is talking about. I get it after running for a couple days without a reboot. The consensus in all the forums I've read is that a daily reboot of the phone is required. This is a problem in all ROMs not just CM7 that are based on the older Android OS and happens to varying degrees and frequency to everyone. Not everyone is affected the same, some people report going weeks without rebooting others need to reboot more frequently.
I've also had the same issues with CM 7 when I was using a flashed theme and then eitheer updated CM7 over it or reinstalled CM7 over it. Themes change the framework and when you install an update or re-install CM7 over them they cause all kinds of force closings and problems. If any of you are using themes other than the 3 provided in CM7 you have to restore a mint CM7 backup, without the theme, before you re-install or update CM7. Doing a full factory wipe of course will also solve the theme problem.
I also get a google framework force close occassionaly when I reboot my phone and I actually cause it to happen by trying to use the phone before it has finished scanning the sdcard. I have 32 GB card and it takes a while for it to load on start up. A quick reboot followed by allowing the phone enough time to scan the card properly fixes this.
Here's something I just posted on the CM forums that worked for me:
I just have an epiphany.
Firstly, I'm running CM7 nightly from 6/22
@optikalblitz: You said Google Music was causing issues. I disabled Music sync, then went into the Music app itself to turn off any sync settings in it. When I opened the app, it loaded for a few seconds, then crashed. I had LogCat running in Eclipse, and the error was a File creation exception stating that I was out of space.
The strange thing is, I'm NOT out of space. My SD card and internal memory have plenty of room. Then I remembered: The Incredible only has about 300 MB of application storage partitioned. Cyanogen seems to work around this problem, EXCEPT for apps from the Marketplace. They will still say there is not enough space. Other install sources (raw apk, amazon, etc), work just fine.
I remembered that I installed Peggle from Amazon yesterday, which was an 80 MB download. I also remembered I couldn't re-install Angry Birds that day because the Market said I was out of space.
So! I uninstalled Peggle and a couple more large apps I don't need, turned all my syncing back on, no DB I/O errors in LogCat, no force closes, no nothing!
So here's my diagnosis:
-HTC Incredible only partitions ~300 MB for applications+data
-Cyanogen lets users install MORE than 300 MB of applications+data
-Android services (such as market and sync) don't understand Cyanogen is doing
-Android services fail gracefully (like market), or not so gracefully (like Sync) when you are out of 'storage'.
-Making sure you have some "free" space in your /data/data/ folder (I have about 30 MB) causes these force closes to stop.
Now, this only worked for me. I can't guarantee it'll work for you, but I was being killed by Force Closes all yesterday, and now they're 100% gone.
PLEASE post back if this works for you!
that actually worked for now. Let's see if it stays that way throughout the week.
i was having a similar issue and then I deleted all my SMS from Handcent and everything seems to be back to awesome.
I noticed mine started acting crazy when i got a picture SMS which is why I deleted all my SMS. so it must have something to do with available memory as stated a few posts above.
I've had this issue intermittently for the last month or so. And previously I did a couple clean reinstalls of CM7. The most recent of which was about 2 weeks ago. That seemed to fix my issues for a while, until last night, when it was starting its madness again.
If the issue is really the available space for apps on the phone versus what CM7 lets you do, I dealt with that by moving a bunch of my larger apps to the SD card, like Peggle and whatnot. As soon as I did that, the phone stopped force closing and everything started functioning normally again. So, this definitely seems like an accurate diagnosis of the root problem.
Just for clarification, does anyone know where I should look to find the available free space left on my phone for apps? I looked under Applications>>Storage Use but that gives me usage out of my total internal storage which is 748MB, as opposed to the 300MB crazydog was talking about. Which number should I be looking at? Thanks!
300 MB is actually too high. It's about 150 for apps and their data. If you use Root explorer, navigate to the /data/data/ folder and you'll see at the top:
148.95 MB used, 48K free, r/w
With the numbers different based on your usage. That's the *real* amount of storage. As you can tell, I am out of room and getting force closes as I speak. Time to move/uninstall some apps. :P
alright, sounds good. I guess I'd need to get root explorer for that, though. I figure, I'll just start deleting/moving apps whenever I start getting FCs. Thanks.
I'm throwing in my suggested solution in here: Wipe dalvik cache and wipe cache partition once a week.
Theory Explanation:
Back when I flashed a new nightly almost every week, I ended up wiping the dalvik cache and the cache partition each time as required. CM7 would run flawlessly.
Then I got tired of flashing a new rom every week, so I tried just sticking to the stable cm7. Then a month or so goes by, and I get a bunch of random FC's. The difference this time, is I'm not doing any wipes. This happened to me with every stable version of cm7.
So now I'm going to try to keep doing wipes once a week, to see if that keeps things smooth. Once a week isn't too bad.
I tried the fix permissions technique without success, and I always uncheck sync contacts unless I want to manually sync my contacts.
Hope this helps.
I just started having problems today, can't use any app without FC after a few seconds. Just read on here there is a problem sometimes with sync and contacts, which I did have when I first loaded CM7. Well I realized I just set today for sync to start if connected to wifi. All I did was turn off Sync and viola no more force closes. Definitely something to look into.
I have this issue from time to time as well, so did my wifes phone. I fixed it last time by removing twitter and facebook... don't know why that worked but it did, worked for my wife's phone too.
A while after the problem went away I put facebook and twitter back on... and a while after that, months later, the problem came back... I'm gonna try it again and see if it works a second time.
update: Yup, removing facebook and twitter fixed the constant fc issues again... not sure why but if you haveing that problem and have facebook or twitter, try uninstalling them and see if it helps.
I had these problems as well in CM7. I figured out it was caused by the "low on space" bug (see the support section for information on that). So clearing cache and data from heavy apps clears enough space in the /data/data partition at the problem goes away.
