what are your settings, prl, ect to get that good. almost too good to be true????Havent done a ton of pulls, but getting over 2k when i never got over 1800 before, not sure I am in a hurry to get a 4G phone.
Odinned FE16 over CTMod 3.6 FA19
Last pulll 2132 kbps![]()
ok but wow, i will try speeds at diff times and see but no way????One thing I noticed when I was tethering with my prevail, is that with full signal I would get around 1000-1500kbps during the day time, but at night time my speeds would increase to 1700-2000kbps eventually during 1-5am I hit around 250-300kb/s speeds.
It might be that your area has less data usage during night time and early morning so you're able to take advantage of it.
I live in West Michigan so Chicago is right across the lake from me, so I changed my speedtest to the closest Chicago server. Go figure, my speed result was 5x's the speed I am getting consistantly from a server here in West Michigan. Kind of an odd result I think considering I'd still be bouncing off the same towers, just changed the servers it's pinging. My ping is actually a lot better from Chicago as well.CTMod 3.6 settings, I have not changed anything, only flashed phone.tar FE16 on top.
edit: I live in a suburb of Chicago so towers are not an issue. Just did a pull at 2351 at 3:58 am local time, really getting crazy now.
edit2: It also seems my pings have dropped 10% or so since losing FA19
No, it doesn't work that way.one thing is when change server to get better tests, will it then use that server???????? if goes back to original then speed sucks!!!
i hear you, man!!!! wish we could pick and choose!!! oh well life goes on.No, it doesn't work that way.
