Fellow Bioni-teers: Post your homescreens
tehsusenoh
Android Expert
I'd love to see what everybody has done to their homescreens on their lovely Bionics. You can screenshot with this app (ShootMe, removed from the market because the reviews got the developer pissed) if rooted, or unrooted, with this guide.
I'll go first. I'm not rooted.
Well then, this seems to be my first post as a Senior Member. Happy days.
Along with the picture should come a description of how to replicate. IE Widgets and custom launchers.
Specifically, what is that widget in the bottom right corner?
Here's Mine:
Beautiful Widgets for clock/weather.
My own self made background.
I am using GO Launcher EX, default theme, with the Vortex Galaxy live wallpaper.
On the top is Elixir 2 Widget.
Then the toggle widgets (wifi, bluetooth, gps, and airplane mode).
Then is Google Music.
On the bottom right is the Circle Battery Widget, the only one I can find to accurately give me a battery percentage to 1 percent. It's normally, white, but it turns a yellow-green when it's being charged, orange when under 30%, then red under 10%.
Thanks for the Battery Widget, going to give Elixir a try as well.:)
I'm getting the runaround from the SDK about installing properly - not going according to instruction in the guide. :( I'll try later when I'm more awake.
I'm surprised that with 2.3.4 we can't take screenshots. Power+home doesn't turn the thing off, but it doesn't capture either.
I keep my homepage fairly simple.
I'm still using the stock launcher as I find it pretty good so far, no lagginess at all.
Beautiful Widgets , and I grabbed that battery widget previously mentioned. :D
Thanks! I had not heard of Go Launcher EX, but downloaded it and after checking out this video I learned how to use it! This is AWESOME!
Android Apps In Depth - 02 - Go Launcher EX - YouTube
Stock Launcher (for now)
Beautiful Widgets (clock/weather)
(Top Row - left to right)
- Speed Dials (from the 'Dialer One' app)
- Audio Profiles (shortcut to my audio profiles)
- K-9 Mail (for my GMail, and other person email accts)
- Stock Email app (for Exchange mail)
(Bottom Row - left to right)
- Stock Phone app (for now ... may switch to 'Dialer One' app)
- Handcent (awesome messaging app)
- Dolphin HD (browser)
how did u change the stock messaging icon to the handscent one? I hate how we cant take the bottom 4 icons off or change them
You can change any of the bottom icons, just long press on them.
Wtf mine wont been trying it since day 1!nope when i long press my bottom 4 (phone,messaging,camera,apps drawer, they just pop up a screen that says add to dock.
Also those same 4 follow through all 5 of the homescreens.Scrolling left to right through all screens and all 4 follow.
Yes, if you click on any of the app icons below in the "add to dock" list that pops up it will replace the icon you just long pressed on.
Great thread. Thanks for doing this. I love seeing what everybody's done and downloaded. I'm in the process of trying to drain my battery right now and have everything turned on and running, but when I can figure out how to do this, I will contribute mine. But here's a question: WHICH home screen do you wanna see? ;-) I have three configured so far and working on a fourth. And I keep messing with it... and, of course, now that I've seen everyone else's and learned about some cool new apps and widgets, I'm going to mess some more, I'm sure... LOL. Plus, I have to swap two of the pages completely because I want different stuff on the "main" home screen!
Edit: OK, nevermind. I am not smart or techie enough to do all that SDK stuff. So I probably won't be sharing a screenshot. :-( Too bad. It's cool. LOLOL!
Nice, sx4dude.
tesusenoh, I may have to try that circular battery app! Methinks you've started the new trend of the week.
I've been playing with LauncherPro and Go Launcher, and decided the stock one is what I need. I'm just using Folder Organizer instead.
Google Search
Beautiful Widgets
Facebook/AIM/browser/market
Email/News/Twitter/Phandroid
Launcher Pro dock:
Dialer/Contact/App Draw/Voice Command/Text
Keeping it simple...
LauncherPro Plus
Beautiful Widgets (with FlatWhite weather skin)
Simple Calendar Widget
I'm definitely a minimalist when it comes to homescreens. I like it simple.
I'm rooted but still using the stock launcher at the moment. I was using LPP on my OG Droid but so far I like the stock launcher though I do miss my scrolling bar at the bottom.
I had been using Beautiful Widgets and still do for some of the other widget toggles but I wanted to try something different with the Bionic and so far, I've settled on the Advanced Clock Widget Pro and like the simplicity of it.
Ok, DroCap2 worked, so here we go, nothing too fancy!
GO Weather
Normal Calendar
Top Row L-R:
GMail
Dolphin HD
Market
Bottom Row L-R
Normal Dialer
Handcent
Vignette
BTW, I have other crap on other screens, I'll post em in a little bit. Also, I have LTE turned off. I only turn it on when Im out and about and need to D/L something.
