Help Few Phonebook Related Problems.
Tommyj
So, pretty sure this has started happening after the update.
First thing is, calls arent logged in. When I go to people > call history, the last one is 11th august.. yet (im not a loner) i've had plenty of incoming, outgoing and missed calls since then.
Also, when i go to do a new message, and try to put a contacts name into the 'search' bar or whatever you want to call it, nothing comes up .. same with the option to select multiple at a time, nothing comes up.
EXCEPT someone i saved a week ot two or something ago, they appear under both the 'quick search' bar .. and the list where you could select multiple contacts, but its only him.
I have browsed the settings and just cannot find the right thing, it is probably something quick and easy but i just can find it :confused:
