Help few questions about rooting
x10iii
im on android 2.1 and im thinking of rooting my fone....
what is the easiest way to root (is there a one-click root app)?
also, will i be able to use different themes and will i be able to remove all the vodafone apps n stuff?
will my fone be any faster?
what are the 5 best root apps?
Simply rooting won't really speed the phone up, but rooting it and installing a custom image or rooting it and then removing some of the built in applications could speed it up.
Here is a recent thread by another user showing scores (the scores are a benchmark test where it kind of ranks the phone after a series of different tests)
http://androidforums.com/sony-ericsson-xperia-x10/257499-ran-quadrant-standard.html
What you want to know before you do anything is what version you currently have and what you want to try and achieve.
If you don't want to void warranty, don't root.
If you have Android version 1.6 installed, you might want to upgrade to 2.1 and give it a go.
If you want to go that extra step and really make your phone fly and remove some of the Sony applications that you might never use, then you could do what I have done....I wrote it all up in a thread here -
http://androidforums.com/x10-all-th...-x10-setting-up-boot-loader-custom-theme.html
I basically upgraded to Android 2.1 and still found the phone sluggish, so I rooted, installed a new bootloader...did a backup of my current image, then installed a custom image which was streamlined and had a nice custom theme....I still messed with it a bit after that, but that was more superficial stuff like changing icons and widgets and stuff after.
I can still go back to normal 2.1 that my cellular provider gave me....but doubt I will...so much quicker now.
few more questions, lol sorry.... the custom rom in ur guide, is it eminence?
and also if i follow ur guide, will i debrand by fone in the process?
k, im gonna get all this done this weekend... how long will this entire process take? do i need to know anything else important/any other apps?
Read, read and read....Once you actually do it, you will be surprised how long it all takes.
From start to finish it would probably take me 5-10 minutes....but the first time I went through the whole process, not knowing what I am doing, it probably took 30 minutes.
hey beau, i have a few questions:
in ur guide u said the xrecovery file must be named xRecovery-0.2-release.apk, but i followed the link u posted and they seem to have an updated version xRecovery-0.3-release.apk.... will this make any difference?
also in the x10 res mod download page, it says the ROM is only for 2.1.A.0.435; is this the build number because my phone's build number is 2.0.A.0.504?
how do i get the latest firmware??
as Beau says - read read read!"! start here ( http://forum.xda-developers.com/showthread.php?p=10879507#post10879507 ) if you want to flash the latest firmware, the tool will do all you need.
Do try connecting to SEUS or PC-companion for the update first as it is available in many regions now.
Hope this helps.
If you find the flashtool useful please send any praise/thanks/donations to the creators (Binary & Androxide) as these guys are the ones who are spending time so we can all enjoy our x10's they way they can and should be!!!
