I think I'm ready to root, but have a few questions before I do.
Background
I've had my S2 (i777) since March - bought it with 2.3.4, and am still there today. I bought my wife's S2 in April with 2.3.6, had terrible battery experience, and rolled her S2 back to 2.3.4 via the instructions on galaxys2root by zedomax (I think I rooted on 2.3.6 and then unrooted back to 2.3.4 - but it's been so long I don't remember for sure). I've read enough horror stories about carrier/manufacturer upgrades that I've stayed away from them - and today both phones are unrooted at 2.3.4, kernel 2.6.35.7.
I have a Nexus7 tablet with JB and a Toshiba Thrive with HC (stayed away from Toshiba's ICS after reading bad reports). But I just rooted the Thrive (it was very easy) and installed an ICS custom ROM - and all seems to be working well. So I think I'm ready to root our phones and install a JB custom ROM.
Questions
1) Can someone point me to the current/best/safest method to root? Should I use zedomax's instructions since it will install CWM (I used CWM during the Thrive root, so I'm at least familiar with it)?
2) If I flash a JB ROM and eventually want to unroot myself back to 2.3.4, can I? Would I just need to make a Nandroid backup of 2.3.4 immediately after I root that I could flash back to, and then unroot via zedomax's instructions?
3) I'm a little unclear on backups via Nandroid vs Titanium. Which should I be doing - both, why? Which backup would I use to flash back to 2.3.4? For the Thrive I made backups via both methods (Nandroid and TB) - when I rooted and was still on HC and immediately after I installed ICS.
4) When flashing a new ROM, how do I get all of my apps and maybe settings on the new ROM? Is this where Nandroid or TB come into play - or should I use an App Backup/Restore app (I've used an App before when needing to do a Factory reset).
5) This may be a subjective question, but what is the "best" JB ROM to try first? It looks like there are half a dozen on XDA.
One other note - XDA kind of scares me. There's lots of technical talk and doesn't appear to be a ton of kindness/patience for noobs. I think most conversation there is geared towards devs, not people like me that might need step by step instruction.
Thanks for any help.
Background
Questions
