Help Few questions
hotguy69
1. Can you change the type of lock you use for your phone and set a specific background for that screen?
2. Can you change the background for every screen you use?
3. How do you keep your own backgrounds from coming out pixelated?
Thanks in advance! Got the phone about 2 days ago and it's my first Droid.
1) To a certain extent. The stock options are located in Menu -> Settings -> Location and Security. There are some apps in the Marketplace that provide different sorts of locks, so explore around. Personally I just use the pattern lock. I don't know of a way to set a different wallpaper just for the lock screen.
2) Not that I'm aware of, at least not with the stock launcher (Touchwiz) or LauncherPro (what I use)
3) Have it be the proper size: 960x800
