Root Few Questions....
Papaniz
Hi there,
I just rooted my HTC Legend, and have a few questions. I got a notification that my phone needs to upgrade to the latest software version, but, I downgraded my version to root my phone, is it okay to update my phone now? Or should I keep it as is? I did not update yet, because I did not want to take my chances. Since my phone is rooted is it unlocked? Can I put a different SIM card and it will work? Or do I need to do something else for that? Thanks for the help.
Hi thanks for the help, I just want to know that if I do install one of these Roms, can I upgrade a software upgrade in the future without having to install another Rom? For example if a new update of Android comes out, I can just upgrade from one of those Roms without having to install a different Froyo Rom?
if it's the same firmware version, you can just update ROMs, if it isn't, you need a new one, but they take like a minute to install so it's not a long time
