Help few questions
karlgixer
right i have desire
1- it wont sync to pc via usb
2- can sms notifacation sound be changed to one of my owm mp3 sounds?
3-how do i acsess micro sd card through the phone?
if you can help me out with any of the above please do so
thank you
karl.
1. In what way - there's a huge thread on here with loads of advice on this. Have a trawl.
2. Open the Messages app, hit Menu->Settings and scroll donw the notification sound. Select the sound you want.
3. Download a File Manager (I recommend Astro).
hi thanks for reply
looks like its an ongoing problem with the sycronisation of the phone
my mp3 file is not in the notifacation files
will try astro
Making ringtones from MP3s is pretty well-covered on the web. Did you even try google ?
Basically you need to put the MP3 you want into media/audio/ringtones (or media/audo/notifications for notifications) either on the SD card - so you can do it via USB to there - or on the internal storage. Note: if you stick it on the SD card it'll vanish (and your ringtone will change) when you mount the SD card over USB.
The syncronization issue you're seeing is probably fixable - many are. Read the thread and if you still have a problem post a question there.
i have been trying all the fix problems mentiond in most posts for the last 2 days and still no good,
i can get the phone on pc as a storage drive but thats it
