fiio e5
Flagship
I was wondering if anyone has used the desire with the fiio e5, if so do it get rid of all the treble and increase bass as well as volume? I'm currently using the sennheiser hd 428 and music still has a lot od treble.
FALSE ALARM!!!!
The connection cables that come with the Fiio are just very tight and I had to apply a little more force to get them properly into the headphone jack. I'll post some thoughts on the amps performance later.
I've been using an E5 for over 2 years now, originally with an archos 5 and now with my htc desire for the last few months. I guess the answer to your question depends on your headphones. I'm using with head-fi RE0 - brilliant earphones but quite a flat treble/bass response. The E5s have a wonderful effect on these - increase the soundstage, give enough oomph to the bass to really enjoy trance/house. Jazz/classical sounds amazing. By the way I'm using spotify premium for all my listening now. The connections are just standard and mine fit fine with the Desire. In fact I have bought a mini-usb to micro in order to use the E5 charger on my phone. Only niggle is that the E5 will very occasionally pick up inteference - it is not fully shielded (and I've had 2). Only seems to happen occasionally when someone sits next to me with a blackberry on the train. Anyway the sound improvement far outweighs any negative impact. I can't do without it!
