Root Files for theming
blaze420916
Android Expert
I need some help I'm looking for a few files so I can theme my phone
1. The file to change the clock color
2. The file to change the toggle color once the status bar is pulled down.
3. The file to change the clocks position to the center of the status bar.
Thanks in advance
If you go back a few pages of threads its all there
There were simular threads that were answered
Infact a guy named Bobzhome posted a link to a page that showed everything avaible
What you need to modify is in the service.jar ir system.ui something like that
If i remember right its coded in old website style xml and stuff
I've been on this forum everyday since before we have had root. I've read every post in the atr section and I remember bobz post but I'll be a monkeys uncle if I can actually find that post lol. I have tried pm'ing samson asking ayeebee and have not heard back from them I was hoping someone could just name the xml files and where they are located. I just need some help and for the mean time I will look for that post with the link from Bob.
Its there somewhere
Center the clock
Maybe sonething like that
There we 2 threads about that like the same week
I think the other guy wanted to remove the clock
I wouldnt know really guys
I am more into performance tweaks n mods
I dont care if its pink or purple
If it goes as fast as possible or can recieve a quarter milliwatt transmission from alaska i am happy
Did you get it centered?
Isnt there a
Ffffff00
Change that and you change the color?
that is a color code. not sure what color it would be, but yes, that would change the color of whatever is referencing that code. i posted in admire_samsungs "My Theme" thread with where he'll need to look. Clock orientation is beyond me, though. Sorry. :(
I thought it was all there in that link
Like you can center or hide the clock and change the color
I havent look at my files but the link seems to be descriptive.
someone suggested using Nova Launcher, and also editing the statusbar.xml in systemui to move/remove the clock, but thats a little beyond me. my APK Multi Tool took a dive. let me see if i can get it up and running again and i'll look a little deeper.
that looks like it would work. not sure if that was meant for CM or stock, but it couldn't hurt to try.
EDIT: Bob says it's something to build into the CM Settings menu.
I'm getting errors trying to decompile so I unzipped did my changes zipped left signature alone and no status bar. I'm stumped can anyone help
