Help Files on my SD card keep disappearing
redgabe
I just bought a brand new 32gb sandisk card. I copied all my old files and used Isyncer to sync my itunes music. It synced fine and all of a sudden, my music and some files have disappeared? Any suggestions? Thanks
Try formatting the card using your phone then try again. You can always try scanning it through your PC for errors. Or since you just bought it, get a replacement.
i just got off the phone with Sandisk. They are convinced the problem is with my phone and my phone is deleting my files ones I put them on to the card. I really don't know what to do.
Mine 16GB Sandisk works just fine. Have you tried another microSD card? Use the PC to check the Sandisk for erros? You tried formatting the card? Has to be FAT32.
