Hi,
I have a HTC DHD and I'm switching from 8GB to 32GB SDHC card. I copied all data from my old card to PC, formatted the 32GB to FAT32 and copied all data to 32GB card from computer. At this moment, PC does see all the files correctly moved to new SDHC card.
But(t). When I map the 32GB card in the phone, most of the files is simply gone. Just empty directories remain (note - I'm using the Astro file manager ). When I look at the SD card properties in the phone, used space is however equal to number what it should be with all the files correctly moved
- this difference in space used is in DiskUsage marked as "System data".
When I put the card in the computer again, files not present in the phone are gone also in the computer. However used disk space is still matching ( weird joke ), but when I select all the files and directories on the card, they have only size of the remaining files ( let's say ~1/3 of used space ) the rest is "elsewhere"
(yes, I do have hidden&system files unhided ).
Please, what is the reason for this card "behaviour"? I'm really desperate...
Thanks
Note : No root, no custom ROM
(yes, I do have hidden&system files unhided ).Please, what is the reason for this card "behaviour"? I'm really desperate...
Thanks
