After using for a few days, here are my thoughts (update from 2.3.3);
1) Pros
a) Wakelogs don't seem to be much more of a problem. Battery doesn't seem to drop as much under sleep condition
b) Nice touch with the blue tinge during scrolling
c) GPS locks faster and more accurate. This alone is worth the update. (Just noticed google map is also updated from 5.8 to 5.11 but still no 6.0)
d) Seems a bit faster in the homescreens.
2) Cons
a) Second day of usage, phone reboots on its own twice. But haven't happen since. After reading some post, I suspect its due to old firmware clashing with new. The best is to clear cache, but if need to factory reset to do it, then probably won't bother since once doing that, have to redo settings and redownload the apps again. Anyone know how to clear the cache without factory reset?
b) The vibrate doesn't work sometimes. Could be due to same reason as 1 and I don't like that the vibrate icon appears in the notification bar all the time. I do set it to vibrate always, but would prefer if the icon only appears when its set to vibrate only (like no sound)
c) Not that much battery improvement. But I suspect that's because I already did some battery management during 2.3.3 like making sure data is off when not necessary and some of the widgets like AP mobile and weather is only sync manually.
Cheers
PS... Its likely that 2.3.5 already have a lot of the pros, so it might not be worth it to update to 2.3.6 if you are already on 2.3.5
I won't know since I went from 2.3.3 to 2.3.6
