Why Razors Edge over the Motofail for ICS?ICS is know to fix data drops but 5.9.905 does not. if you want to root 5.9.905 use motofail if you go to ICS use razors edge.
to get motofail http://androidforums.com/bionic-all...-all-things-root-guide-updated-2-14-12-a.html
to get razors edge http://t.co/mbIAmwH8
There is a Motofail made for ICS, I used it. Downloaded it from a link over at XDA.
I just installed ICS and rooted it. I used to think my phone couldn't get much better, now I know I was wrong. This is incredible.
So what is the difference between loading CM (or any other rom) and stock version of ICS? I thought I would have to flash a rom in order to run ICS on my bionic. Is this not true?
