theotherrogue
I know there are a lot of methods, tips, tricks out there, but after spending multiple nights trying to get root to work, I got it. I thought it would do some good to share my info.
I'm using an ADATA SD card (4GB class 6). Many people have reported varied success with this card.
I was able to get this method working twice successfully by following these steps exactly. No other steps I've tried have worked:
- Download the files linked to here with mejdam's 10 minute video. Files: http://goo.gl/mfhc
Extract to sdk folder as he instructs:
YouTube - Droid Incredible Root in 10mins
(follow his directions on all other steps not indicated here)
- Boot your phone normally (HTC Sense).
- Plug in USB.
- Change to "Charge-only" mode for the usb connection.
- Enable USB debugging.
- Power off normally (don't pull battery).
- Disconnect USB.
- Hold VOLUME DOWN + POWER.
- Wait for update messages to pop up and disappear.
- Press VOL DOWN to highlight "Recovery" (don't select it yet)
- Remove and reinsert SD Card.
- Connect USB.
- Start loop.bat in command prompt.
- Now, press POWER to select recovery.
- Rapidly remove and reinsert SD Card until the very moment the /!\ icon comes on screen. (You should do the last SD card re-insert immediately after the /!\ icon appears).
- This is when I FINALLY got the "exec '/system/bin/sh' failed: No such file or directory (2) -" to appear.
- Now, you can follow all additional steps in the video for superuser permissions, enable tethering, then use UnrEVOked tools, etc...
