Frisco
=Luceat Lux Vestra=
..screen blanking when attempting to input from the number pad during a call.
The screen would go blank so quickly that I did not even have time to input one digit. It was behaving as if I'd kept the phone at my ear instead of holding it down in front of me so that I could use the keypad to continue in the menu of the place I'd called.
I am not sure if I've cured it or not; I did a live battery pull about an hour ago and have made several calls without the glitch happening.
I'd like to know if anybody else with an Eris on 1.5 has had this problem, and if so, if you've found a reason and/or solution. Did a battery pull do the trick? At another site a factory reset was suggested, which is something I'd rather avoid unless absolutely necessary.
