Doing all that doesn't automatically enable moving to SD. There are specific steps needed to enable move to SD, and more than 1 way to go about it.
The method I chose was to create a second partition on my SD card and use Link2SD to move apps of my choosing. That is probably the least invasive method since you aren't changing the stock ROM in any way, and it doesn't even need busybox, just root and supersu.
There are at least a few other methods to choose from.
