yeah I was happy the date update was announced but had no luck didn't even see the video settings buttonI have Tango and it works pretty well. Give it a try.
Cool, next time I am over at my friends house I will install the app and try it out.
Maybe he will be able to finally start using the web cam.
Is there a version of Tango for PCs?
Now you can video chat with Skype on your Acer a500 with the new Skype update. Head over to the market and check it out.
I tryed on my Acer a500 the skype no camera only sound and chat. Is there anything to setup?
help pls
HiYou have to go into the settings and enable the video calling option.
Hi
I didn't found anywhere settings for skype.
Can you tell me which could be the steps to take ?![]()
Once you sign in tap the grid looking icon in the status bar at the bottom then settings, scroll down look for enable video calling and check that box
Hope that helps![]()
Yes I have the most recent version, but for good measure I also tried some older versions just in case, and I can quite assure you that on my tablet, the option is not there.do you have the most recent Skype?
I can assure you it is there.
**edit** maybe not in canada?????
