Find and Accessory? Post it here!
Mr. Ed
Extreme Android User
Post any links to accessories you find here please.
User pics/opinions of your accessory purchase encouraged.
There are a variety of accessories for the LG Spectrum at the Verizon Wireless website. I recently purchased the desk charger with additional standard battery...and it is a nice product. I tried to post a review at Verizon's site...but for some reason it isn't showing up. Maybe it will later.
Overall..this is a nice charger and is solidly built....and does what it says. When you put your phone in the cracle and plug it in the fixed charging arm...a cool little desk clock/calender shows up. However...I gave it a 4 out of 5 because if you have any type of protective casing on your phone...even if just a rubber rear covering...the phone charger won't properly fit in the cradle...and evern worse...the charger at the top wont line up with the charging arm. But since it is only $10.00 higher than what Verizon charges for just the battery...having a nice charger for the extra battery is worth the extra $10.00. And even if you don't use it to charge the phone...it can still serve as a desktop cradle for your phone even in the case. Also..it comes with a charger that is identical to the one that comes in the box with the phone...so you get a second cherger/usb cable.
Hope this helps!
Here is the link..... http://www.verizonwireless.com/b2c/...ryDetails&archetypeId=12966&accessoryId=49930
Just got the slicone case from the verizon site. I really like it. it fits nice and tight, and its not very buky. Phone still has a nice feel, actually a little better feel IMO.
Set Your Location
Fixed it for you.
I got that one when I got my phone. I like it alot. The phone won't slide around cause of the cover material. Only thing I don't like about it is that it shows smudges and smears really bad.
I picked up a basic anti-glare screen protector from Amazon and it works well, though it does attract a lot of lint and dust due to its static nature...
It appears that Zagg mkaes an invisible shield for the phone. they list one for e Revolution 2 VS920. Looks to me like the Spectrum, which is the VS920.
LG Revolution 2/Spectrum VS920 Screen Protector | invisibleSHIELD by ZAGG
update: purchased and installed last night, this 100% for sure for the Spectrum.
Yep, got mine installed last night as well. Works perfectly. Well, I got my wife's on perfectly anyway. Mine, not so much. I dropped it on the floor, adhesive side down of course, and so I will be ordering a new one. :mad:
ouch thats sucks... mine keeps peeling up on the edges a little from my silicone case, and has a very light 'orange peel' looks to it. Not too ba di guess for my 1st time installing one. Still works great and makes me fele much better having it.
