find my phone
gazza25
hi, i have just brought the htc one m8, is there a find my phone app if there is how do i find and use it thank you .
i have downloaded this app, have tried to find my phone and it says unavailable, i have made sure boxes all ticked accound registered etc... ut no luck , does anyone know how to fix this thanx.
hi , it says unavailable after trying to find my phone i have adjusted all settings have also cleared cache reset phone etc.. still nothing, i have tried on my google account but that says the same .
try these steps
If your Android device doesn't appear in Android Device Manager, or if you see Unknown location despite your device being online and running Google Play services version 3.2.25 or higher, follow these steps:
Open Google Settings from your device's apps menu.
Touch Android Device Manager.
Uncheck Allow remote factory reset.
Go to your device's main Settings menu, then touch Apps > All < Google Play services.
Touch Clear Data. Note that this action doesn't remove personal data.
Go back to Google Settings and select Allow remote factory reset.
Restart your device.
you might have to unselect remote factory reset to clear data in Google play services. After clear data the go back in select it again, reboot you should be good to go.
Source
Try this:
1) Remove your google account from your phone
2) Reboot
3) Add your google account back
4) Reboot
5) test android device manager with the phone NOT connected to wifi.
if that doesnt work, i recommend a factory reset.
good luck
thanx for all the help, have decided just to take device manager off phone and will look for another find my phone app , cheers
