N nicknak Lurker Jul 27, 2014 #1 Can you set up the find my find on he or do you need to,download app. If so what app is best.
L lexluthor Android Expert Jul 27, 2014 #2 nicknak said: Can you set up the find my find on he or do you need to,download app. If so what app is best. Click to expand... I like Cerberus https://play.google.com/store/apps/details?id=com.lsdroid.cerberus&hl=en I did get it when it was free once though. I do like the fact that I can manage multiple phones with 1 login.
hilmar2k Android Expert Jul 27, 2014 #3 Android Device Manager works well. No app required (though there is one).
rdillz Well-Known Member Jul 28, 2014 #4 I use "GotYa". It doesn't get much better than this for smartphone security. https://play.google.com/store/apps/details?id=com.myboyfriendisageek.gotya
D dubie7006 Well-Known Member Jul 29, 2014 #5 hilmar2k said: Android Device Manager works well. No app required (though there is one). Click to expand... Didn't even know this existed. Awesome! Just tested everything and it works great.
