Finding folders
  • Start date Start date
A
Android Question
Guest
Okay, so
I made a folder in my internal storage on my computer to put some music onto my android phone. And it is done loading and copying into the folder.
Now where can i find that folder on my android phone?
If you install a free file explorer from the play store (there are many - HERE) you should be able to browse to its location on the device.
If you mean an app isn't finding the files that you transferred, sometimes it can take awhile for new media to appear. Try restarting the device and the new media should appear in the appropriate places.
