Finding Quikoffice documents
BWRpota
For some reason my phone no longer recognizes the MicroSD card. So I connected my phone and laptop using USB, to locate a doc I typed up to send to laptop.
I could not find the .docx file. Looked in My Files, could not find the External SD folder. Where is it? It's weird that I have no external SD inserted, but can still save a doc to "External SD".
could you see any files on the External SD CARD? Have you tried putting the card in to a card reader and viewing that way? Try doin that and tell me if you can view the files or if windows wants to format the disk?
When I use the card reader on two different laptops, neither will recognize the MicroSD..
I was storing the card within the adapter, then in a tiny ziplock bag, and then this in my billfold.
Do you think maybe it was damaged somehow?
UPDATE: The MicroSD is recognized by one of the laptops; it just took a little time.
Yes, Windows does want to format the disk.
I would rather make sure that there's nothing on there I want to keep before formatting.
Not possible, huh.
BWRpota;[URL="tel:5914963" said:
5914963[/URL]]When I use the card reader on two different laptops, neither will recognize the MicroSD..
Not possible, huh.
Sounds like its damaged. Make a backup of it, just in case you can't mount it again.
Not possible, huh.
lets try to run chkdsk on it
chkdsk x: /f /r <-- replace x with the drive letter windows assigns it.
place the disk into a card reader do not try to do this with it in the phone
I suppose I'd have to insert the disk into the laptop which will recognize it in order to run chkdsk
