Help Firefox overlapping fonts issue
Hey all,
First off, I did a search and it turned up nothing. Here is what happened. I was using the ROM Toolbox to change the fonts on the device because it offered a large variety of fonts. After downloading all the previews I went ahead and changed the fonts to the one I picked. Now, doing this required a reboot per the app, so I accepted and allowed the ROM Toolbox to reboot the phone.
Upon the reboot completing, everything acted very strange. I had no service, I could not access the menus, and actually I could not do anything. So after 5 minutes of trying to do something, anything I realized that a battery pull was needed. So I did that and as soon as the subsequent reboot was complete, everything worked just as it was supposed to. So I let out a sigh.
At this point, everything seemed to be ok. Then I went into Firefox because I wanted to check something out on the web, and as soon as I did the fonts in Firefox were all overlapping. It seemed the default fonts were overlapped with the new font that I just switched to. So I went back into the ROM toolbox and attempted to revert back to the default font and no luck. Nothing changed in Firefox even though it changed the fonts everywhere else back to normal. No matter what I did or where I changed the fonts the Firefox fonts were messed up and would not adjust or correct itself.
I even attempted to uninstall Firefox, redownload and install it but that had no effect either. The fonts remained screwed!
So does anyone have any ideas how I can rectify this problem or what may have caused the issue?
I also have another question. When using an app such as ROM Toolbox or anything else to adjust say the fonts, what app takes ownership? What I mean is there are like 3 or 4 places where the fonts can be changed since I added that App and who knows what other apps allow font changes. So when that is the case, which app takes priority over the rest and has the final say on what font is used? Is there a certain app hierarchy that is utilized by Android for these situations? Not just for fonts, but for ANY changes that are made... there has to be...
Thanks again guys!
You might try removing the Android/data/org.mozilla.firefox directory after uninstalling FF. Also mount your SD card on a PC and seee if there are any hidden FF or Mozilla directories. If no help, you might post something to the Mozilla forum.
Since having this issue originally, I have wiped and flashed a new kernel and ROM to the phone. Of course, doing so cleared up any issues with FF since EVERYTHING was deleted.
However, since I am not one to leave things incomplete, I reinstalled the software in question and tried to replicate the original errors. Problem is, I cannot.
I am thinking that I may have ended up getting a corrupted fonts file when I was switching fonts through the launcher and then through the original Touchwiz settings. That is all I can think of anyway. BUt like I said, I tried to replicate the errors with the fonts and could not. I even tried a couple different ways from the original way it occurred and still no luck.
I'm sorry about that guys. I would have really liked to find a fix for this because I can see something like this happening again to someone. Having a fix would be nice.
Either way, I thank you guys for posting replies and some wonderful suggestions. They all made perfect sense and were very helpful. If only I still had the issues :rolleyes:
