Under settings-check for updates, it is telling me there is a firmware package update available. Anyone tried this or know what it is?
Yeah, there is an update rolling out which supposedly fixes a few things. not much else is known right now.
Failed to update.
Got an 8507 error forsure.
Don't know what that error means.
I was looking forward to this update since my phone always freezes and resets all the time.
The issue I have is I don't want to activate a new phone on my service and discontinue the first one just to find out. Would it be updateable over WiFi w/o activation? I have an unrooted one htat we can test with
Are you rooted? If yes, have you changed any of the system apps?
Yes and yes. I uninstalled some apps then i reseted my phone still rooted.
Does anyone know the reason for the update? I suspect that it is to address the security flaw described here. This article is worth reading in any case, since it discusses how android fragmentation leads to many phones lacking security patches
‘Fragmentation’ leaves Android phones vulnerable to hackers, scammers - The Washington Post
How do i update with these files because i still don't have the update
copy the update file to the root of the sd card and reboot in recovery mode. Follow the on screen prompts from there under update.
r
I doubt it would work this way, considering the files don't ever touch the sd card.
Also, I successfully updated. I was rooted, and am still rooted. I didn't do anything special except for remove the files I replaced, and restore the backed up files. Honestly, not sure what problems everybody is having. Maybe there are issues downloading it over 3g vs WiFi?
