Help Firmware update failed
I tried to do my first firmware update (with Tim 4e) but I got problems.
The update procedure started well, but soon showed the following error message:
"discovery
Hi,
Are you sure the files are correct?
Could someone post the correct md5sums [I only have s0I's firmware so I can't] so luciano can check them against his files?
Regards
tbod
"discovery
Finally I had sucessfull !
Probably the problem may have been that i used my mobile phone as USB reader to format the card.
Now I used another card in a PC with build-in card reader. All happened as expected!
Thanks for the help guys.
