tell us how you got the clockword mod on there and what cw kernel you used
I did some testing and am beginning to think that the key signing for the Superuser.apk is being rejected. Android requires that all apk's be signed otherwise the app will never show up in the list of applications. I checked and Superuser.apk is signed and valid however it is possible that the key is on a reject list. If this is the case then I'm unsure how to remove it from the list of invalid keys. If we could get the maker to re-sign with a different key as a test it would help. I've dropped him an email and will see if he replies.
In the meantime, I got rid of the annoying startup sound. I removed /etc/PowerOn.snd and /etc/PowerOn.wav after remounting the /system drive.
You can do adb push <local> <remote>. If <remote> is a directory then make sure the / is at the end of it.
Oddly enough, the app I'm playing with is signed and should load from what I can tell but it won't show up. His video talks about how the new recovery does not allow unsigned zips, different than what i'm dealing with.
i used that but didnt get clockwork modGalaxyS One Click Root All Models...
. So yeah thunder I tried the blank password, and for some reason it tells me the password isn't correct.i used that but didnt get clockwork mod
OK, so is there any way to push the update.zip in there or is there any way to get to the real external sd card from clockworkmod? yes, I am able to boot and reboot after I installed clockworkmod recovery.That is the directory listing of /data, only accessible if root however /data is a seperate device from /system and under normal mount is rw.
i have a tester...what do you want me to do?? im still trying to get clockwork mod on there and i cant seem to do it without odin...when i flash the cwm with odin the phone gets stuck in a boot loop...talk to me fellas, lets whoop this sob
you haven't bricked your phone, man, have you?????
I ordered some fru units so I have some to play with...I bricked one flashing some of the other kernels so ill send that back but now I have a fresh one again plus my personal one....ill order two more tomorrow just in case
Give me play by play on cwm please
What is a FRU unit?
that is correct, if i brick them i just send them backfield replacement unit, apparently?
