earlgsxbusa
Member
OK gang, I usually dont post as I am busy reading lots of info here! THanks to all!!
Ok I Pre-Ordered the Photon on the 28th - I received it on the friday 12pm 7/29 So i have been working and tweaking and discovering with this phone.
As a background - I have been using the EVO rooted since it has been out. I love my EVO and it did have its nuances.
Lots of Pluses with this phone
- Screen is Smooth,Quick, Responsive and brightness and color is more rich than the EVO.
-Speed - this is super fast. as far as I can see using (System Panel-Pro), the CPU's run on 1 mostly, but depending on the app, both can run at the same time. This is opposed to a thread i had read that the 1st CPU will max out then the 2nd will add to it. Regardless of how this behavior is, it is FAST!
-Physical feeling of the phone is pretty solid. it is a few grams heavier than the EVO, but I personally like that it feels like a real Device.
-Moto Blur - it is better than it used to be. I am spoiled with the EVO Roms I had with Sense2.1 / Sense 3.0 built in. I basiclly replaced Blur with Launcher Pro Plus and restored my settings that I am familiar with as well as adding an ICON pack to change the icons.
- Lock Screen I also downloaded the Agile Lock (from Market and Paid) Why? Because I love the Sense 3.0 Style lock ring. Again personal preference.
-The Music app is really good for Stock. I usually use MixZing Premium. I will have to explore more into this app for a more detailed review. Overall, it is a strong application. Wish it would give more of an option to force an update for lyrics,CoverArt
- Battery Life is way better than the Evo. Usage is better than i expected and I have been beating on this phone LOL. It charges pretty fast as well. So my grip with the batter indicator is the 10% increment. What that means, it shows 100% even though you are at 92%. But yet it shows 80%, but Im at 82%. How am I getting these numbers? I am using System Panel-->Monitor and it shows a more of a real number vs an average. I also have Battery Indicator Pro, but it reads what the phone has in Settings-->Status. SO....try System Panel Pro to see whats happening with battery levels. I am hoping that there will be an update to address this within the Photon.
-SOund Profiles - Ok So I am able to use the Volume Rocker to change from Ring tone to Vibrate, but couldnt "silence" the phone completely. THis is good for meetings when you want now vibrate or sounds to disturb you. I use a Widget from market called "SilentMode" - I know there is a way to do it from stock, but just didnt look in every place. Maybe someone can tell me here.
- Memory - there is no SD card, so I used my 32GIG from my EVO. There is 16G internal, but half is utilized for OS and Apps as most of you have read. I did however, check the boot loader Power&Vol-Down and saw that it does have a bit of options. I tried them but I am locked out. So i am thinking that a big chunk of the 16Gig is partial to this bootloader as well. So we'll see what the team at XDA will discover. I hope root soon
-Phone Quality - well its good so far, but as someone else who noted in this forum, it does have a "cave" like sound in the ear piece when talking. So I am not sure how I feel about this so far. People on the other end do say I sound loud and clear though. Here is an issue though, if you sweat alot and it runs down your face while you are talking, it will drip into the mic and give that muffled-in-cup-sound. ( i know its disgusting, but it happened).
So thats the nuts and bolts with this for now. I hope this info help people who are deciding to get or already have this phone
I am loving it so Far
