First off, Verizon is sending an awesome protective case that doubles as a stand...it has several notches on the base of the stand configuration so that you can tilt the tab to the desired angle. I wasn't paying attention when the rep put the case on, it was just another add on to the 700+ bill
. But when I got home I realized it was also a stand that allows me to break out a cubical anywhere at any time
. The stands lays real comfortable on your lap or on tables, etc.
If the the screen isn't high def, its pretty close
. Everything looks razor sharp. The battery seems adequate. I started at a 100% charge, and after reloaded apps from my Google account and some web surfing, its in the low 80's which is great. I have yet to test some notorious battery drainers like YouTube or Movies, but for standard activities the battery is good.
A lot of fun drawing app time wasters here, all with my faves, Google maps, etc. There's a page and a half of apps already installed. The speakers aren't defening, but they're way louder than my Galaxy 7.0. I could clearly hear it on a noisy bus, which wasn't the case with the 7.0.
More later, but I'm very impressed with it so far, the wait was worth it.
. The stands lays real comfortable on your lap or on tables, etc.If the the screen isn't high def, its pretty close
. Everything looks razor sharp. The battery seems adequate. I started at a 100% charge, and after reloaded apps from my Google account and some web surfing, its in the low 80's which is great. I have yet to test some notorious battery drainers like YouTube or Movies, but for standard activities the battery is good.A lot of fun drawing app time wasters here, all with my faves, Google maps, etc. There's a page and a half of apps already installed. The speakers aren't defening, but they're way louder than my Galaxy 7.0. I could clearly hear it on a noisy bus, which wasn't the case with the 7.0.
