First Post - Newbie Shortcut Question..
Deleting shortcuts on the application pages doesn't seem to work.
I press the shortcut icon I want to delete, hold, wait for the vibration, drag to the garbage icon, and release. When I go back to the application page the shortcut icon is still there.
This technique works perfectly on the home pages, just not on the application pages.
What am I doing wrong?
you have to delete programs through: settings > applications > manage applications > (select desired application you want to delete) > Uninstall
some programs will not let you delete them as they are locked by t-mobile.
So even though Avatar isn't really a proggy, I can't kill the shortcut?
I understand about the apps I can't get to without rooting, but figured Avatar might be different.
