Root First time rooting! Would like some help!
Jaxon2580
Hey guys,
So heres the thing.. I got this epic 4g on christmas coming from a samsung moment(dont know if that important or not) and immediatly after I got it I learned about this rooting and roms and kernals ect ect ect. And its just soooo confusing.. Anyways all id like to do now is a simple and safe root for this phone so I can overclock it and use a free wireless tether so if you guys could help thatd be great! again I just want a simple safe root
Thanks!
Hey guys,
Thanks!
here ya go, simple and safe:
One Click Root & Recovery for the Epic 4G! v2.5.5 Now has ClockworkMod Redirector! - xda-developers
let us know if you have questions doing it.
Hey Yogi,
I just got my epic as well, I noticed that the tread was made back in August. Are you sure it is still valid and will work with all the new updates that the Epic received? Have you used it and what is the success rate?
Mike
Mike, if you want to go with an ext4 rom, use this to root:
http://forum.xda-developers.com/showthread.php?t=897612
I just threw the first one up there because he said he wanted something safe and easy. They are both equally safe and easy however.... you just need to read up and decide if you wanna go ext4, which is what most of the latest roms are using.
[MOD] Ported Clockwork Mod version 3.0.0.5 [READ OP CAREFULLY!][RELEASED!] - xda-developers
Hey thanks Yogi,
It seem like they made it real simple. Can you possible direct me/us to the appropriate place to load rom? Thanks, I know I could of just used a Google search but it seem finding good information from reliable sources are hard to come by these days.
Thanks!
Hey thanks Yogi,
Thanks!
yes, no problem. the site xda-developers.com has pretty much everything you would need. more specifically, check out the epic 4g Android Development forum there:
Epic 4G Android Development - xda-developers
have fun!
edit: there is also now one rom for the Epic available right here in this forum..... check out the thread on midNIGHT ROM!
