Root first to do this?
bz3491
so, as many people probably do I am running cm9 on my triumph and today while browsing the market and in all of my glorious intelligence I decided to dl instagram since its available for android...
anyway it does not work on cm9 lol
just thought I'd share.
Well, it works on my Kindle Fire and that doesn't have a camera. Are you saying that the app doesn't work at all, or that you can't take pictures with it?
well its probably cm9 that causes the camera to not function therefore not allowing camera apps to work.
But the app works even if there is no camera, so it may be something else. Which is what I was trying to say when referring to my KF (that has no camera).
@OP does the app work at all besides taking pics? Like the network part or the filter stuff on lics on the sd card (not actually trying to take them)?
I was able to install the app on CM9 and do everything besides post pictures. Not sure why you're having a problem.
instagram off the market is broken.
I installed a thunderbolt and droid incredible 2 build.prop mod and none made it work.
It only worked after sideloading the apk. now it works and updates JUST FINE, even on stock build.prop. but the market version didnt work.
once u get a version that works, it works VERY well.
cm7 1.2GHz ondemand
of course i can t take pictures with cm9 bit instagram does work on my m/t
as a side not did yall dee where google purchased theCAUSE Instagram app fo 1 BILLION dollars funnny thing is the finicial experts valued it at 500 Million why pay twice aS MUCH AND YOU BETTER USE IT CAUSE IF GOOGLE HAS IT THEY WILL END UP SWLLING IT AS SOFTWARE, JUST IMAGINCRETA A APP YOUR A BILLIONARE
I thought FB bought it.
Facebook bought it. Rolo is correct. Google has nothing to do with it.
