Root Fission rom manager 1.2
droid_freak
Fission ROM Manager 1.2 is out and has auto install features, for ROMs at present and all other files to come. Loaded Fission 2.3 using it to test and other than the download stalling, it worked like a champ.
i downloaded it to check it out. i am currently running apex. just clicked on the menu button from within the app and the SU permission came up. i hit allow and the phone rebooted with my data and cache cleared. not sure what happened just a warning.
they forgot to remove a debugging developmental feature from the FRM.
so when you hit the menu button it will clear data and cache.
you have been warned! :)
unfortunately, i read this just AFTER this happened! i guess this a good time to be glad i have a fairly recent backup...
I am interested to know why I had no problems, I downloaded it mins after the twit from Angdroid and had no problems. :/ Very strange!
its only if you hit the menu button. i just hit it to see if there was any options in the app. its a hidden developer function that they forgot to remove.
Got thanks for clearing that up I guess I was not paying very good attention to your post. :eek:
