Root [FIX] Boot Loops (Please post yours)
WhisperPntr
Note that this is mostly for people who have rooted and are in the process of flashing recovery, etc. to their phone. If your phone is freezing, randomly rebooting, and feels hot to the touch etc. this is likely a hardware issue. You can rule out software issues by going into recovery (from a powered off phone press and hold back, volume down then power) and factory resetting. If that doesn't work, return the phone asap.
Please post in this thread your boot loop fixes and when I have time I'll credit you and include all in here for easy diagnosing.
  1. LG Logo Boot Freeze/Loop
    • Install LG drivers and QPST (should not require root)
      1. Start phone in download mode (power off phone, Hold down volume rocker, connect usb cable)
      2. Open up QPST Configuration
      3. Remove existing ports and add the auto-detected one
      4. Open up Memory Debug app and then click restart phone.
  2. VM Animation Loop
    • Factory Reset
      • Start up the phone in Recovery Mode (hold Volume Down, Power until it starts in recovery mode)
      • select factory reset.
