I've recently noticed some problems with my 3g after going back to gb. My wife's phone(unmodded), would connect to 3g in a matter of seconds where mine would take 10 seconds or more. I think there is something not quite right with the gb baseband that we've all used. This, along with wrong IMEI because I flashed roms before the 5irom backup, started getting me frustrated with my phone being messed up. We've all made mistakes with our phones with flashing and so on, consider it a learning curve. So I set out on a mission to try and get my phone back to normal.
Last night I was searching for stock firmware for the u8665 fusion 2 and I stumbled across another forum with a link. This link gave me an update file for our phone that takes it back to stock completely. I mean, just like it was when we took it out of the box. That means, it fixed my 3g, it gave me my original IMEI back, no root, no cwm, everything was stock!
Now, I can mod to my hearts content and NOT make the same mistakes as the first time around, and back up everything that needs backed up. All I had to do is root, install cwm, and I'm on my way. I know there are several people in the same boat as I am so I'm going to post a link to the file and the forum page where I found the file. The instructions are in the zip file with the UPDATE.APP.
Good luck and happy modding. Here's to not making the same mistakes the second time around!
First link will be the file link and the second will be the forum link.
http://www.mediafire.com/download/2l4y0dafldh07ch/HUAWEI_FIJI_firmware(U8665_Android_2.3_V100R001USAC07B037_USA_AT%26T_05010VXD).zip
In need of Huawei U8665 ATT firmware [SOLVED] - GSM-Forum
A big thank you to elcapitel, whoever you are, for posting this file for download.
