[FIX] GPS broken in FK23 Jellyverse v.3 - UPDATED FIX FOUND
dhabell
Did anyone else get their GPS broken by FK23? How do I fix?
EDIT - see fix in my post below....
V
I can honestly say the my gps takes a while to kick in and sometimes not at all. Hopefully I could figure out what is wrong cause I absolutely love this rom. If anyone has fixed this or knows how to fix please let me know... thanks
I found an odd fix that works for me. Toggle the gps on and off for like 3 times. Seems to work for me.
It only happens after a boot, after the toggling on and off, it works fine until a reboot again
Ok I found the fix.
This is for Jellyverse v.3 with FK 23 kernal and modem.
It was easy as the fix is already included in the Rom. I just used Titanium Backup to erase the data from the Google Maps Application, then I used TB to erase the Google Maps cache. Next I ran the GpsFix Application from the Play store. Finally I ran the Google Navigation app.
voila.
If this works please press the thanks button.
