heythereitsv
This is an MMS fix for this EXCELLENT ROM by mike1986. on XDA. What Android Revolution HD is is basically a stock ROM, but prerooted with speed tweaks and fantastic battery life for this phone (this gets me through the entire day!). It's designed for people who like the stock HTC experience, but want some speed/stability improvements + debloat. For best results, install with 4EXT, HBOOT 1.57/1.58, and S-OFF.
Here are the instructions to flash this ROM, fully working for our Evo V-
1) Download the ROM and fix found here
2) Boot into recovery
3) Flash the ROM
4) In the middle of the process, it should ask you if you want to keep Sprint apps, if you say no, this does not touch the HTC apps!
5) After flashing this ROM, DON'T REBOOT!
6) Go to mount menu on 4EXT
7) Mount /system
8) Punch in the following commands in ADB
9) Do a full factory reset (wipe data/cache/dalvik-cache)
10) Reboot into Android Revolution HD!
*posted with permission from mike1986.!*
Some extra goodies to make this ROM even better! Flash these right after installing the ROM and pushing the fix for best results-
-Camera Mod! Download the Sprint base version, works like a charm.
-Google Now! I personally use M7, first one I tried, and seems to work fine.
After flashing one/both of these mods, I suggest another factory wipe. Enjoy! ^_^
3) Flash the ROM
7) Mount /system
Code:
adb remount system
adb push *where you put my fix* /system/framework
