Saxön
Seems the multiple fixes to resolve the stock mms issues when using marky beats either work or they don't for some unknown reason which in my case they all did not.
I deodex'd and fixed the stock boost mms.apk (at least it works on mine & three friends so far) and being inspired by all the hard work towards this project I felt that I had to try and contribute in some small way... I hope this fixes this for the rest of the ppl that are left with this issue
I have used this successfully on MB 1.2 & 2 w/either stock or Hyper kernals consistently with no glitches sending pics/slideshows.
Obviously use and do this at your own risk as I am not responsible if you jack your phone up!
1) Download apk here: mms.apk
2) Go to settings/applications/all/ select mms.apk and clear data.
3) Download and install Root Explorer if you don't already have it.
4) In Root Explorer goto system/apps and make folder R/W and backup/rename your mms.apk just in case.
5) Copy/paste the downloaded mms.apk from the link above in the system/app directory and change permissions to rw-r--r-- and change folder back to RO
6) Reboot and make sure your mmsc setting is correct.
MMSC Fix Link
Note: I did this with all messages deleted in all cases, but not really sure if it matters.
Thanks to all putting forth the effort and sharing knowledge... you guys rock!!!
-= If This Was Helpful Hit Thanks =-
MMSC Fix Link
