Root Fix Permissions Error
Please help me!
when i try to run fix permissions in rom manager, it says an error occured while attempting to run specified commands.
I know i was rooted but for some reason set cpu wont work and i cant access any other rooted apps. rom manager wont let me recover to an old back up either.
Android version- 2.3.3
im running the latest gingerbread rom supposedly.
baseband version c_01.43.01p
kernel version 2.6.32.9_0.6ghz_sv_v0.1 root@pete #46
build number GPA 14
I have also tried installing busy box but it says im not rooted when i supposedly am.
please any help would be appreciated!
Do you have the Super User app in your App Drawer? Otherwise, type in "su", minus the quotations marks into Terminal Emulator.
Ike, doesn't make sense. GPA14 is a rooted rom, but your phone doesn't appear rooted.
Did you do a complete data wipe before the install? If you can't resolve it, go back to the site you found GPA14 and I'd suggest you email the author, Pete Alfonso. He may be able to help. Neall
