Root [Fix] Uninstalling Beats Audio.
I've followed this guide using my phone, and i'm noticing that most of the files mentioned in the guide aren't there to begin with. Its still a helpful post and a step in the right direction, but simply uninstalling the driver won't fix any problems, at least from my experience.
I got it from Motioncoding's facebook page, I've noticed a lot of people had been complaining about it and they told everyone who asked to do this. I would suggest sending them an email or something, I'll try to ask them as well. Can yu send me a copy of the files?
which files exactly, i've since removed the files mentioned in the guide so its a bit too late if that's what you're asking about.
but i'll definitely send the devs an email about it and hopefully they'll have more insight on it
Which were some of the files that said to uninstall in the Beats Uninstaller that weren't in the RiSE? Devs seems to respond right away in their facebook page, so I'll there.
i also waqsn't paying attention when installing beats and damn if it didn't give me the same probs as on this thread.
i think i may have found system files for the hydro, but unfortunately i don't really know what i'm looking at. could anyone with the know take a look and maybe if they are, point out the audio drivers and specify where on the phone they should go to replace the bad "beats" drivers?
i can't post links yet so lets see what i can do.
github dot uknow, forward sl, hroark13, /hydro_kernel/tree/master/sound/drivers
of course this is past the start but i'm sure one who know can backtrack and find what is needed.
i hope this helps all.
and thank you to whoever takes this on and helps us idiots.
yo guys delete beats normal haha thene everything is good. At least with My Lg Venice.
When i Installed It turned my network off and was EXTREMELY slow and i could go on the internet because it restarted such as various other apps such as back up apps. so i downloaded Root Browser Lite and went to system\bin and delete both beats things
I also could not find all the files listed in that PDF. Here are some that were missing on my phone:
/system/bin/basimage_gec.bin
/system/bin/basimage_gec_x.bin
/system/bin/dynimage_gec.bin
/system/bin/dynimage_gec_x.bin
/system/bin/mm-audio-acdb-test
/system/bin/mm-venc-omx-test720p
/system/bin/mm-video-encdrv-test
/system/bin/peqimage_gec.bin
/system/bin/peqimage_gec_x.bin
plus about 24 others
I've attached that PDF with the missing files shaded in gray. Some of the files I found were named slightly differently from those in the PDF, and the ones I did find are in purple text.
:confused:
have you fix your problem already? im having the same problem too im using xperia miro plz helppp:(
Ive just been caught out by the beats audio app and now ive also got a continuous boot loop on my xperia play r800i 2.3.4 and it doesnt help that im new to rooting and have no clue how to fix it :(. if someone could please help me i would be most grateful.
