iSergiwa
Member
Have you ever waited it for more than 4 seconds (or more) so it can rotate to the way you're holding it?
Have you ever put it on the desk and it went landscape by itself?
Has it ever got stuck on landscape mode until you restart it?
If you had any of these issues with your Note 2 auto-rotation then don't worry, it's not a hardware problem, it's the stock TouchWiz UI. Just install any other launcher (I recommend Go Launcher EX) and the issue will be resolved.
Hope that helps.
Hope that helps.
